crwdns2959928:0crwdne2959928:0 ↓This guide provides instruction to remove and replace a depleted battery in your Orbic Wonder. Before beginning, discharge your Orbic Wonder battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Turn off the Orbic Wonder prior to disassembly.
Remove two 2mm TR9 Torx screws from the bottoms of the device.
There is a border between the black phone backing and the silver screen.
Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
When the halves are parted correctly, the gap should look like this.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
crwdns2935267:0crwdne2935267:0Tweezers$3.99
Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
There is a black flap on the bottom of the battery.
Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
where do you buy the replacement battery at ?
ricotoomo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can I buy a replacement battery
Robert Smith - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you big help your smart
gansterms123 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
