Motherboard Replacement guide for Oral-B White Pro 1000 rechargeable electric toothbrush due to faulty operation. This guide illustrates the disassembly of the Oral-B White Pro 1000 electric toothbrush. Use caution not to short the positive (+) and negative (-) terminals when handling the battery. This guide also requires the use of a soldering tool which reaches high temperatures. Refer to this helpful guide for some great soldering and desoldering tips.
Remove the brush head by pulling the top away from the base.
Pry open the end cap from the toothbrush body.
Remove the spring.
Apply pressure on the brush shaft to release the toothbrush internals.
Remove the internals through the bottom of the toothbrush body.
Use flat head screwdriver to remove power button pressure plate.
Desolder the coil wire from the motherboard.
Squeeze and remove coil from motherboard.
Desolder the motor from motherboard.
Remove motherboard and battery from body of toothbrush internals.
Desolder the battery connections from the motherboard.
Remove motherboard from battery holder.
Reattach new motherboard and reassemble your device following instructions in reverse order. Solder appropriate connections during reassembly.
Motor are brushless?
