Oral-B Vitality Power Button Replacement
  1. Oral-B Vitality Power Button Replacement, Power Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Power Button Replacement, Power Button: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Power Button Replacement, Power Button: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
  2. Oral-B Vitality Power Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 4 terminals connecting the power button to the circuit board.
  3. Oral-B Vitality Power Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Power Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Power Button Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder the 4 terminals and remove the old button.
    • Remove as much of the old solder as possible.
  4. Oral-B Vitality Power Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Attach the new button by soldering the 4 terminals with new solder.
crwdns2935229:08crwdne2935229:0
Grady Bennett
crwdns2935283:011/07/17crwdne2935283:0
509 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G1, Harley Fall 2017 crwdns2935289:0IUPUI, Team S2-G1, Harley Fall 2017crwdne2935289:0
IUPUI-HARLEY-F17S2G1
crwdns2947412:05crwdne2947412:0
In my case no need to change the button, just redo the solder and this is it.
the vibration has damaged the solder.
Al kri - crwdns2934203:0crwdne2934203:0
If you try to unsolder the battery it has some protection and it won't work anymore
Gigi Kent - crwdns2934203:0crwdne2934203:0
Before unsoldering the button, you can understand if it is good or not just bypassing it with a wire: with a copper wire you can touch two pins of the button (one on the right side, on on the left side); if the toothbrush starts and stop on each touch of the wire, the problem is the button. I recognize the problem in this way.
Manolo Cerello - crwdns2934203:0crwdne2934203:0
True except if the switch is permanently “on”. I think that was my case. Replacing the switch fixed the issue.
Mumble Tim -
In my case the inside of the case of the toothbrush where the cover for the start button is, was worn. I cut 3 - 3/16" squares of electrical tape and placed it on top of the start switch. This filled the gap where the worn material was and enabled the switch to be activated easier. I also noticed that some moisture was inside the case of the toothbrush, so I coated the metal shaft protruding from the toothbrush, and the o ring of the cap with some water proof grease, Vaseline.
Robert Carl - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 111
crwdns2942667:0crwdne2942667:0 12,008
