Oral-B Vitality Power Button Replacement
  1. Oral-B Vitality Power Button Replacement, Power Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Power Button Replacement, Power Button: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Power Button Replacement, Power Button: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
    I just fixed a UK model, looks identical on the outside but doesn't have the twist lock, instead has two shoulders/catches, one parallel with the switch and the other on the opposite side. I opened by gripping the toothbrush with pliers the same way but then levered it open once I'd made a gap.
    Erik Carlson - crwdns2934203:0crwdne2934203:0
  2. Oral-B Vitality Power Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 4 terminals connecting the power button to the circuit board.
  3. Oral-B Vitality Power Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Power Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Power Button Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder the 4 terminals and remove the old button.
    • Remove as much of the old solder as possible.
    I managed to strip the top left pad, but fear not, only the bottom two pads (shown with tracks leading away) seem to be actually used to complete the circuit.
  4. Oral-B Vitality Power Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Attach the new button by soldering the 4 terminals with new solder.
crwdns2935229:08crwdne2935229:0
Grady Bennett
crwdns2935283:011/07/17crwdne2935283:0
509 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G1, Harley Fall 2017 crwdns2935289:0IUPUI, Team S2-G1, Harley Fall 2017crwdne2935289:0
IUPUI-HARLEY-F17S2G1
crwdns2947412:05crwdne2947412:0
In my case no need to change the button, just redo the solder and this is it.
the vibration has damaged the solder.
Al kri - crwdns2934203:0crwdne2934203:0
If you try to unsolder the battery it has some protection and it won't work anymore
Gigi Kent - crwdns2934203:0crwdne2934203:0
Before unsoldering the button, you can understand if it is good or not just bypassing it with a wire: with a copper wire you can touch two pins of the button (one on the right side, on on the left side); if the toothbrush starts and stop on each touch of the wire, the problem is the button. I recognize the problem in this way.
Manolo Cerello - crwdns2934203:0crwdne2934203:0
True except if the switch is permanently “on”. I think that was my case. Replacing the switch fixed the issue.
Mumble Tim -
In my case the inside of the case of the toothbrush where the cover for the start button is, was worn. I cut 3 - 3/16" squares of electrical tape and placed it on top of the start switch. This filled the gap where the worn material was and enabled the switch to be activated easier. I also noticed that some moisture was inside the case of the toothbrush, so I coated the metal shaft protruding from the toothbrush, and the o ring of the cap with some water proof grease, Vaseline.
Robert Carl - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 109
crwdns2942667:0crwdne2942667:0 12,006
