Oral-B Vitality Battery Replacement
  1. Oral-B Vitality Battery Replacement, Remove toothbrush head: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Battery Replacement, Remove toothbrush head: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Battery Replacement, Remove toothbrush head: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull off head, and use pliers to remove the white cap. Pull out the circuit core.
  2. Oral-B Vitality Battery Replacement, Remove toothbrush head and inspect board, battery, and motor: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Battery Replacement, Remove toothbrush head and inspect board, battery, and motor: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oral-B Vitality Battery Replacement, Remove toothbrush head and inspect board, battery, and motor: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Inspect four pads with green circles (Picture #1), they should be fully covered in solder.
    • Picture #2 shows the center pad missing some solder and not making a good connection.
    • Picture #3 shows repaired solder pad. Test toothbrush battery and motor operation without toothbrush head. If toothbrush is now working, there may be no need to replace the battery - if battery is providing between 1.2 and 1.5 volts and motor is actuated by button presses, stop here and reassemble the toothbrush.
    • If battery voltage is less than 1.2 volts, consider testing motor operation and button presses with two tests; using a AA battery and a pair of wire leads touch one end of leads to battery ends and the other wire ends to: A) left board pads (to test motor leads) and then B) to right board pads (to test battery leads, center pin is positive).
    • If motor doesn't start after Step 2 troubleshooting, continue to Step 3.
  3. Oral-B Vitality Battery Replacement, Desolder motor and battery leads: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oral-B Vitality Battery Replacement, Desolder motor and battery leads: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • De-solder in these four (4) locations.
    • The two (2) motor connections
    • The Positive (+) side of the battery
    • The Negative (-) side of the battery
  4. Oral-B Vitality Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oral-B Vitality Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • De-Solder lower battery connection terminal. Bend back battery terminal to clear circuit board.
  5. Oral-B Vitality Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • De-Solder the three (3) upper terminals from the circuit board.
  6. Oral-B Vitality Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use plastic prying tools to carefully pry off the circuit board. (Utilize metal spedger as a last resort)
    • There is a white tab that goes through the board, be careful when removing the circuit board.
  7. Oral-B Vitality Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oral-B Vitality Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the circuit board and battery assembly out. Then proceed to remove the battery from the circuit board
  8. Oral-B Vitality Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When re-installing battery, remember to bend down lower terminal. And the negative (-) terminal is closest to the copper wires
    • Ensure you recharge the toothbrush after the repair. Even if the replacement battery is already fully charged, the toothbrush will fail to power on if you don’t recharge the toothbrush.
To reassemble your device, follow these instructions in reverse order. Remember to apply just enough solder to re-attach the terminals.
crwdns2935229:018crwdne2935229:0
Miles Gunty
crwdns2935283:011/07/17crwdne2935283:0
564 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G1, Harley Fall 2017 crwdns2935289:0IUPUI, Team S2-G1, Harley Fall 2017crwdne2935289:0
IUPUI-HARLEY-F17S2G1
crwdns2947412:010crwdne2947412:0
This is very easy to do. I had no problems following your instructions.
Ian Bowker - crwdns2934203:0crwdne2934203:0
Thanks.
Is this a regular rechargeable AA?
Thanks again.
Stephen Shaw - crwdns2934203:0crwdne2934203:0
The original battery is a NiCd with tabs. I just spot welded tabs onto a standard AA NiMH battery and it worked fine.
T C -
Thanks.
I did fix an Oral B Braun PRO timer (2022) and the only part that is different is the head. It has two nail presses inside, one at the switch side and the other at the opposite side, that are very difficult to lose.
Peter M. - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 26
crwdns2936753:07crwdne2936753:0 169
crwdns2936753:030crwdne2936753:0 710
crwdns2942667:0crwdne2942667:0 54,614
