Optoma HD72 Projection Lamp Replacement
  1. Optoma HD72 Projection Lamp Replacement, Projection Lamp: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to loosen the single captive 2 mm screw that secures the small lamp panel on the lower case.
    • Remove the panel.
  2. Optoma HD72 Projection Lamp Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to loosen the two 2 mm screws on the bottom of the projection lamp housing.
  3. Optoma HD72 Projection Lamp Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Optoma HD72 Projection Lamp Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the panel off of the device using the metal handle.
    • Disconnect the pink wires from the black plastic housing.
  4. Optoma HD72 Projection Lamp Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Optoma HD72 Projection Lamp Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Optoma HD72 Projection Lamp Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the four 2 mm screws that secure the lamp to its housing.
    • Remove the projection lamp casing by gently lifting the bulb from its housing.
  5. Optoma HD72 Projection Lamp Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Optoma HD72 Projection Lamp Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the bulb is out, replace it with another bulb and re-secure the housings in reverse order to this guide.
    • The second photo is what the completed bulb housing should look like.
Oscar Garcia
crwdns2935283:002/07/24crwdne2935283:0
677 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-5, Kilpatrick Spring 2024 crwdns2935289:0University of North Texas, Team 2-5, Kilpatrick Spring 2024crwdne2935289:0
UNT-KILPATRICK-S24S2G5
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 133
