crwdns2959928:0crwdne2959928:0 ↓Use this guide to remove the fan from your Optoma HD20.
Twist the focal cap clockwise until it is fully extended.
Remove the focal cap by pulling it straight out.
Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
Use a plastic opening tool to gently pry the top cover off of the device.
Remove the ribbon by disconnecting it from the main circuit board.
Lift up the clip holding it down and pull the ribbon out.
Peel off the tape that is holding the metal casing down.
Use a Phillips #1 screwdriver to unscrew the nine 4.5mm screws.
Use a Phillips #0 screwdriver to unscrew the three 2.5 mm screws. This will allow you to remove the metal casing.
Remove the metal casing by lifting it up off of the circuit board.
Unplug the six wires stemming from the circuit board.
Use a Philips #1 screwdriver to remove the four 4.5 mm screws
Remove the three 4.5 mm screws using the Philips #1 screwdriver.
Remove the two 4.5 mm screws located on either side of the VGA/SCART port using a 5 mm nut driver. This will further release the plastic backing from the motherboard.
Slightly rotate the motherboard clockwise. This will prevent ports from getting caught on the plastic backing.
Lift the plastic backing to remove it.
Lift up the motherboard and take out the metal container beneath it.
Unplug the white connector underneath the right side of the circuit board.
Use a Phillips #1 screwdriver to remove four 5 mm screws. This will release the fan.
Pull the fan away from the metal housing unit.
Gently lift the fan up and out of the device. The fan is now removed.
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
Graveyard Workshop - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Do you know where to get this fan for replacement? Having trouble finding a parts list.
Sterling Grogg - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Small fan is GB1245PKVX-8, large fan is KDE1285PTV1
Gyrovague - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
merrill277 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
Mike Popov - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
