Opening the iHome iH9
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Opening the iHome iH9, Backup Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening the iHome iH9, Backup Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening the iHome iH9, Backup Batteries: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the tab towards you and lift up to remove the battery cover.
    • Remove the two AA batteries.
  2. Opening the iHome iH9, Opening the iHome iH9: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 8mm Phillips #2 screws.
    • Unscrew the six 25mm Phillips #2 screws.
    • Reinstall the backup battery cover so it is out of the way.
  3. Opening the iHome iH9: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening the iHome iH9: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening the iHome iH9: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the backplate up with a plastic opening tool between the back plate and the speaker grill.
    • Be careful when lifting the bottom plate up; there is a short white and orange 4-pin connector attached to its underside.
    • Lift the bottom plate up while making sure the connector remains attached.
  4. Opening the iHome iH9: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening the iHome iH9: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening the iHome iH9: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to flip the backing plate away from you and rest it upside down on the iH9.
    • Unplug the white and orange 4-pin connector by pulling it in the direction of the wires.
    • Set the backing plate aside.
  5. Opening the iHome iH9: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the device so that the speaker grill is face down.
    • Remove the two 10mm Phillips #2 screws on interior sides of the speaker housings.
  6. Opening the iHome iH9: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Opening the iHome iH9: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the iH9 upside down.
    • Wires connect the core assembly to the housing; do not attempt to pull the core assembly completely out.
    • Using both hands, pull the housing siding away from the device while simultaneously lifting the motherboard and speaker assembly straight up.
    • Repeat for the other side.
  7. Opening the iHome iH9: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Stand the iH9 on its grill.
    • Separate the motherboard and speaker assembly by rocking it back and forth and pulling the assembly towards you.
    • Remove the small back panel.
  8. Opening the iHome iH9: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening the iHome iH9: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening the iHome iH9: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly pull the wide 9-pin connector with black covering on the underside of the upper housing to unplug it.
    • Lay the housing and core assembly flat and close to each one another.
  9. Opening the iHome iH9: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Opening the iHome iH9: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the narrow 9-pin connector from the motherboard.
  10. Opening the iHome iH9: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the zip tie holding the wires together with a wire cutter. The two sides of the device housing are now fully separated.
Curtis Wathne
crwdns2935283:001/31/15crwdne2935283:0
397 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-39, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 8-39, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S8G39
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 65
