Opening the Olympus E-PL1 Case
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Opening the Olympus E-PL1 Case, Opening The Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the gray tab down, using a spudger if necessary, and the battery will come out.
    • Failure to remove the battery prior to disassembly can result in harm.
  2. Opening the Olympus E-PL1 Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening the Olympus E-PL1 Case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening the Olympus E-PL1 Case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are a total of six screws that must be removed using the the #000 Philips screwdriver.
    • As per picture one: there is one 4.9 mm Philips head screw on the left side of the camera.
    • As per picture two: on the bottom of the camera, there are three 3.4 mm Philips head screws; these are located on the darker area of the case.
    • As per picture three: there are two 5.3 mm Philips head screws on the right side, one is beneath the USB cover.
  3. Opening the Olympus E-PL1 Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the case by peeling off the back panel.
    • Pull the case apart gently so that the ribbon connector will not tear.
  4. Opening the Olympus E-PL1 Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Opening the Olympus E-PL1 Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two ribbon cables as shown in picture one.
    • Avoid using metal pry tools, as shown in the photo, on internal electronic components, as it can cause a short and damage the device. Use an ESD-safe tool such as a standard nylon spudger.
    • To disconnect a ribbon cable, use a spudger to lift the black tab then pull the ribbon out. This works the same for all ribbon cables.
  5. Opening the Olympus E-PL1 Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back panel has now been removed.
Jeffery Smith
crwdns2935283:003/11/15crwdne2935283:0
795 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 9-1, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 9-1, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S9G1
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 134
