Opening the Column in the Hamilton Galileo
  1. Opening the Column in the Hamilton Galileo, Opening the Column in the Hamilton Galileo: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Opening the Column in the Hamilton Galileo: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Opening the Column in the Hamilton Galileo: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Opening the Column in the Hamilton Galileo: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
Ian Van Sciver
crwdns2935283:004/09/20crwdne2935283:0
332 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G26, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G26, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G26
crwdns2942667:0crwdne2942667:0 195
