Opening Philips Senseo Quadrante
  1. Opening Philips Senseo Quadrante, Opening Philips Senseo Quadrante: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Opening Philips Senseo Quadrante, Opening Philips Senseo Quadrante: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Never forget: Power off and unplug your device before starting repairs!
    • Remove all attachments such as cup rack, pod holder and water tank.
  2. Opening Philips Senseo Quadrante: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device so that the rear of the machine is facing you.
    • Remove the two Torx T15 screws at the bottom on the machine.
  3. Opening Philips Senseo Quadrante: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The side panel must first be detached at the bottom edge. Turn the machine so that the bottom is facing towards you.
    • There are two indentations on the base plate with catches inside each one. Press in the catches with a screwdriver and detach the side panel at the bottom edge.
    • Chances are the plate will get stuck. It is recommended that you use a plastic pry tool to avoid scratching.
  4. Opening Philips Senseo Quadrante: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Opening Philips Senseo Quadrante: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At this point, the side panel is still snapped into place on the front, right next to the coffee spout. You can use a screwdriver to carefully pry the latch open.
    • On the inside of the side panel there are two pegs on the top edge that fit in the holes. Lift the side panel up and out.
  5. Opening Philips Senseo Quadrante: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The heating element can be seen immediately after the side panel is removed.
  6. Opening Philips Senseo Quadrante: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening Philips Senseo Quadrante: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening Philips Senseo Quadrante: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • User a screwdriver to release the catch at the top of the electronics cover.
    • Lift out the cover.
    • Both the electronics and the pump will be visible once the cover is removed.
Follow the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
269,384 crwdns2915208:0crwdne2915208:0
crwdns2935297:0301crwdne2935297:0
Descriptifs et photos des opérations bien détaillés, pour mon HD 7864.
Un petit détail pour le démontage du disque de distribution d'eau il y a une encoche avec 2 flèches face à face, faire levier avec petit tournevis pour le déclipser. Merci bonne continuation 😉👍
Gerard - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 115
crwdns2936753:030crwdne2936753:0 462
crwdns2942667:0crwdne2942667:0 16,149
