Open the Melitta Caffeo Solo
  1. Open the Melitta Caffeo Solo, Opening procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the power cord!
    • Remove the water tank and drainage tray.
    • Remove the side cover and remove the brewing unit.
    • Remove all coffee beans.
    bei meiner Maschine muss ich die Schale 3-4 mal rausnehmen / einsetzten damit sich das Signal von „dauerhaft an“ auf „blinkend“ einstellt, deutet das daraufhin das der mikroschalter getauscht werden sollte. Übrigens, danke für das tolle Tutorial ..lg Tom
    Hans-A Shole - crwdns2934203:0crwdne2934203:0
    Problem ist behoben, Schalter getauscht, Position des Schalters ist bei der Caffeo Solo 950 sehr gut erreichbar. Alter Schalter konnte auch wieder gangfähig gemacht werden und dient nun als Ersatz.
  2. Open the Melitta Caffeo Solo: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove six Torx T10 on the rear.
    • Lever the rear cover off. It will most likely be quite stuck and you will need to apply some force. You must use plastic lever tools to prevent damaging the cover.
  3. Open the Melitta Caffeo Solo: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Open the Melitta Caffeo Solo: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press carefully into the slits on the sides using a minus screwdriver or a flat metal spatula, to release the clasps on the upper surface. These may be well tight and you have to use some force.
    • You should have created a separation between the upper surface and side panels. Now lever the upper covering away using a plastic tool. This may be quite stuck and you may apply some force.
  4. Open the Melitta Caffeo Solo: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a plastic tool in the crack between front panel and left side panel and widen it. Then push the side panel to the back. The side panel will be quite stuck and you may apply some force to do this.
    • Remove the hose from the water tank to the pump.
    • Remove the side panel.
    Hi, I have a Melitta Caffeo Solo E950 and had a problem with the switch (it said that the drainage tray was always in while I removed it).
    I was able to access the switch right after the step 4 behind the side panel.
    Paul
    Paul - crwdns2934203:0crwdne2934203:0
  5. Open the Melitta Caffeo Solo: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a plastic tool into the crack between the front panel and the right side panel and widen it. Then push the side panel to the back. This may be quite stuck and you may need to apply some force.
Follow the steps in reverse order to reassemble the device.
crwdns2935229:010crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
265,456 crwdns2915208:0crwdne2915208:0
crwdns2935297:0297crwdne2935297:0
Many thanks for this, the procedure turned out to be exactly the same for my Melitta Avanza Series 600.
Fixiepixer - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 79
crwdns2936753:030crwdne2936753:0 398
crwdns2942667:0crwdne2942667:0 20,124
