Open a Saeco Minuto
  1. Open a Saeco Minuto, opening procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the power plug!
    • Remove the water tank.
    • Remove all the coffee beans.
    • Remove the brewing assembly.
    • Remove the drip tray and the coffee grounds drawer.
  2. Open a Saeco Minuto: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Open a Saeco Minuto: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Open a Saeco Minuto: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up with a plastic opening tool at the bottom edge of the chrome-plated cover to lift up the coffee dispensing spout. This cover is often very tight, so you have to pry hard and hope that the part does not break.
    • When the lower edge of the spout is released, you can pry on the side edge until the chrome cover comes off completely.
  3. Open a Saeco Minuto: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Open a Saeco Minuto: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Torx T10 screw at the top edge of the coffee dispensing spout.
  4. Open a Saeco Minuto: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Open a Saeco Minuto: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift off the black cover over the coffee dispensing spout. The sliding nozzles will come off at the same time.
  5. Open a Saeco Minuto: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both Torx T10 screws on the left and right at the bottom edge of the coffee dispensing spout.
    • Pull off the hot water dispensing spout.
  6. Open a Saeco Minuto: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Open a Saeco Minuto: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Torx T20 screw on the finger guard of the grinder. Remove the finger guard.
    • If the screws are covered with coffee remains, you should first clean them with a needle and a vacuum cleaner.
    • Remove three Torx T10 screws in the bean container.
  7. Open a Saeco Minuto: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three Torx T10 screws under the water tank.
  8. Open a Saeco Minuto: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Open a Saeco Minuto: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Open a Saeco Minuto: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the upper cover on the sides and lift it up.
    • The cover is still connected with a cable and a tube.
    • Take off the silicone tube.
  9. Open a Saeco Minuto: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the water level sensor cable from its brackets.
    • Carefully remove the plug from the water level sensor.
    • The cover is now free and can be removed.
Repeat the steps in reverse order to reassemble your device.
crwdns2935229:042crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
285,049 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2947412:027crwdne2947412:0
Hallo, habe versucht das bei HD8844 zu machen. Allerdings gibt es hier am Kaffeeauslauf den zusätzlichen Hebel (Espresso/Cafe). Der lässt sich via 2 seitlicher Torx entfernen, aber letztlich lässt sich Schritt 4 nicht durchführen. Selbst bei entfernten Schrauben scheint die Hebelhalterung zu blockieren und niemand (es haben mehrer Personen probiert), schafft es die schwarze Abdeckung des Kaffeeauslaufs zu enfernen um die beiden Torx für Schritt 5 erreichen zu können. Irgendwelche Ideen?
s.ruso - crwdns2934203:0crwdne2934203:0
Kenne dieses Modell leider nicht. Hier ein kleiner Hinweis.
VauWeh -
Und hier viele Bilder. Hoffentlich hilft es.
VauWeh -
Leider kann man mit dieser Anleitung nur die Haube entfernen. An einer Entfernung der seitlichen Abdeckung bin ich gescheitert, das Ding scheint aus einem Guss zu sein, ich kann die Pumpe von der Seite nicht freilegen. Saeco Minuto HD8761
Matzewol - crwdns2934203:0crwdne2934203:0
Hmm. Kann mich gar nicht mehr richtig erinnern, ich meine das ginge ganz leicht?! Ich muss sowieso demnächst wieder eine zerlegen, vielleicht kann ich die Beschreibung fortsetzen.
VauWeh -
crwdns2936751:024crwdne2936751:0 17
crwdns2936753:07crwdne2936753:0 89
crwdns2936753:030crwdne2936753:0 363
crwdns2942667:0crwdne2942667:0 76,783
