Open Case
    1. Open Case, Open Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Open Case, Open Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Open Case, Open Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Clean the coffee machine before starting as well as possible and remove any remaining coffee bean debris, etc.
      • Pull the power plug before working on the coffee machine!
      • Never submerge the coffee machine completely under water.
      • Remove the drip pan, tray and container for used coffee,...
      • ... the water tank, ...
      • and the aroma protection cover.
    2. Open Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Open Case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • One hurdle: the back is attached with four special oval-head screws. They look like rivets. To remove them, you need an oval-head bit. In a pinch, you can also use a good pair of pliers.
    3. Open Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Open Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two T15 Torx screws from the coffee machine housing cover.
    4. Open Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Open Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the top cover of the coffee machine.
      • Remove the panel from the right side.
      • Slightly lift the side panel at the back and then pull it out backwards with a little effort. Especially when disassembling it for the first time, the force required for this can be quite high.
      • Remove the left side panel.
      • A light tap on the back of the recess for the water tank can help to loosen the side panel.
Do you need help extracting the grinder of your Jura Impressa F50 to service it or replace it? Then check out the guide "Extract and Replace Grinder".
crwdns2935229:014crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Natalie
crwdns2935283:005/08/19crwdne2935283:0
759 crwdns2915208:0crwdne2915208:0
KMM 2019SS crwdns2935289:0KMM 2019SScrwdne2935289:0
Community
crwdns2931471:011crwdne2931471:0
crwdns2935297:048crwdne2935297:0
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 193
crwdns2942667:0crwdne2942667:0 16,229
