In this guide, some soldering is required when disconnecting the speakers from the motherboard. If you are unfamiliar with soldering, watch Soldering Tutorial for Beginners, Five Easy Steps to familiarize yourself and to be able to correctly replace the speakers.
Use the plastic opening tool to remove the rubber caps from each end of the speaker.
Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
I bought this 6 months ago, it works pluged into power source, but once unpluged will not work. Even being left on charger over night.
Also i pluged it in the red light is on but glows dim then bright. Is this normal?
I bought it off Amazon brand new
I cannot believe I am unable to find one video to show how to properly open up the speaker to fix the female port.
I WAS VERY HAPPY with my speakers untill the ports malfunctioned a year after purchased. No warranty and NO illustrations ABOUT opening the housing without damages using PLASTIC TOOLS AS RECOMMENDED .
So now I have great speakers that are now disposable since I cannot open the %#*@ housing.
Great product until it is charged ONE too many times.
Cant replace drivers if you cant buy replacement drivers!
Use the plastic opening tool to remove the front speaker plate from the speaker.
Remove the eight (8) 5.25mm screws with the Phillips #0 screwdriver.
Open access to the speakers by letting them rest as shown.
Use the soldering iron to carefully disconnect the speaker(s) from the motherboard connection wires.
Learn more about soldering here.
Remove the disconnected speaker(s).
crwdns2935229:013crwdne2935229:0
crwdns2947412:08crwdne2947412:0
Where do you buy replacement speakers?
Where do you buy the replacement speakers?
What type to buy?
where i buy the speaker replacement/
Where can i buy the replacement speakers
same question, I am looking for original speaker for oontz angle 3 and I can’t find one. Those who are looking for the size, its 40x40mm (1.57”) 4ohms 3W
I contacted Oontz recently and was told they have no replacement speakers and that my only option was to purchase a new gen 4 speaker. Guess its the secondary market for me..
I TOO tried to go through the manufacturer only to find out they don't bother supplying parts for their products! I'm needing replacement speaker drivers because the speaker magnet just fell off of the driver itself What I did find out is they supposedly don't know who makes the parts that goes into t their own speakers.
How many inches of speaker does an Oomtz Angle come with?
Where do I buy the OontZ Angle 3 Motherboard?
David Dy - crwdns2934203:0crwdne2934203:0
