In this guide, some soldering is required when disconnecting the battery and the speakers from the motherboard. If you are unfamiliar with soldering, watch Soldering Tutorial for Beginners, Five Easy Steps to familiarize yourself and to be able to disconnect the battery and speaker.
Use the plastic opening tool to remove the rubber caps from each end of the speaker.
Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
I bought this 6 months ago, it works pluged into power source, but once unpluged will not work. Even being left on charger over night.
Also i pluged it in the red light is on but glows dim then bright. Is this normal?
I bought it off Amazon brand new
I cannot believe I am unable to find one video to show how to properly open up the speaker to fix the female port.
I WAS VERY HAPPY with my speakers untill the ports malfunctioned a year after purchased. No warranty and NO illustrations ABOUT opening the housing without damages using PLASTIC TOOLS AS RECOMMENDED .
So now I have great speakers that are now disposable since I cannot open the %#*@ housing.
Great product until it is charged ONE too many times.
Cant replace drivers if you cant buy replacement drivers!
Locate the soldering connections for the battery on the motherboard and the wires for the speakers.
Use the soldering iron to disconnect the battery wires from the motherboard.
Use the soldering iron to disconnect the speaker wires from the motherboard.
Remove the three (3) 3.6mm screws using a Phillips #0 screwdriver.
Use the plastic opening tool about midway down one side of the motherboard to pry it out of the casing.
Remove the faulty motherboard.
Hay..
My motherboard is not the same as the picture above. Is my Oontz Angle 3 not genuine? I am from indonesia
What type of replacement usb charging hub is this ?
dj madd monkey and dj jenna magic in the house 🏡
we have these pairs of oontz angel 3 bluetooth speakers love ❤️ them
but we accidentally damaged the charging ports and need the replacement motherboards i took both apart ready to install new replacement part the rest of the speakers are in perfect shape
we want to get back to the music 🎶 without hooking up larger speakers 🔊
especially when we are having our practice sessions these come in handy as monitors
i purchased the youxiu but they dont hit as hard as these oontz bluetooth speakers do
if anyone can help me find the oontz website maybe me and jenna can get the parts we need
also i wish they used the iphone ipad charging port usb instead of these usb type c or
better yet the wireless charging capability upgrade requests from
dj madd monkey aka johnathan and dj jenna magic aka jenna
crwdns2935229:09crwdne2935229:0
crwdns2947412:015crwdne2947412:0
where do i buy mother board of oontz angle 3?
how much does a new motherboard cost??
Can you post where to get a new MB?
It does require a part...the new motherboard!
I'm having a hard time tracking down motherboards too. But the guide is still helpful if someone wants to harvest a motherboard out of another broken Oontz and use it in their own. If anyone else finds a source for the motherboard, feel free to edit the guide and include a link to it in the details section. Maybe if we all work together we can find a source.
If everyone sends in a request for parts on their support page, it might push them to provide replacement parts in the future. I know I know, It's a long shot, but manufacturers need to know parts are desired or they will never offer them here's a link to email their support team. https://theoontz.com/pages/email-our-oon...
Anyone located motherboards for these yet. I need one.
if I wanted to just replace the USB charging port itself can someone please direct me to the correct one to purchase?
Tech store wants $65.00 to look at Oontz angle 3 because the charging cord has to be pushed very hard in for the red light to start charging. That's just to look at it, not parts!!! Once I let go of the cord, it stops charging. I only paid less than $30 for it and will certainly not spend another $65.00 for it. Would be nice to have a longer warranty than 90 days. I think this started happening around the 95th day I had it. Would not recommend this speaker at all. I'm not paying double what I paid for it or replacing the mother board on a piece of equipment 3 months old. Very disappointed for sure.
take a razor blade and shave a small amount off the plug on all four ends
It, sadly, is simply a poor design issue quite widespread throughout the electronics industry. After more than 25 years as an engineer, I’ve seen problems like this a lot. I’m sure Cambridge Soundworks has some really sharps electronics engineers, computer engineers, coders, etc. What they probably don’t have - guessing - is a really sharp structural or mechanical engineer on staff, contract, or retainer for the real-world physical stress analysis and design. That is almost unheard of and it is the source of the problem - from the physical design of standard components such as USB ports to the connection of such components to the motherboard and such. As Judy (above) pointed out, these items are so inexpensive in terms of replacement purchase price to repair cost, the incentive to address these issues is lost in the massive volumes produced and the roll-out of new models.
Where I can buy a Oontz angle 3 Ultra motherboard???
If you want repair of Oontz, send email to f16skypilot@gmail.com and we can discuss terms
Where to purchase mother board
Dimna saya membeli motherboard baru
Where do I buy the OontZ Angle 3 Motherboard?
David Dy - crwdns2934203:0crwdne2934203:0
