The battery of the OnePlus X is located behind the glass rear panel. Use this guide to remove the battery and disconnect it from the motherboard.
Power off the phone by pressing the button on the right side of the phone, it will be the smaller button.
Press and hold the button down for a few seconds, until the option "Power Off" appears on the screen.
Select "Power Off" on the screen to turn off the phone.
Insert a SIM card removal tool into the small hole located on the top right corner of the phone, just above the volume buttons.
Push the removal tool into the hole and the tray should pop out.
Remove the SIM tray from the phone.
Using a heat gun, apply slow and even heat to the edges of the back panel.
While heating the back panel, use a Jimmy to test if the adhesive is soft enough to allow the panel to separate from the device.
Carefully detach the back panel, using opening picks to hold the panel apart from the device.
Once most of the edges are separated from the device, attach a suction cup to the back panel.
Press the suction cup to the back panel to secure it.
With the help of the suction cup, pull up on the panel to completely detach it from the device.
Using a PH000 screwdriver, remove the following seven screws circled with red and orange:
Four (longer) PH000 screws
Three shorter PH000 screws
Once all of the screws are removed, proceed to using a plastic spudger to pry the metal cover off.
There are two clips near the bottom, right above the battery, so start by prying on the bottom edge of the plate.
Once the metal cover is removed, locate the battery connector wire, which clips into the motherboard.
Using a plastic spudger, gently pry on the clip to release it.
On the battery, locate a clear tab. This will be used to pull the battery out.
Firmly grasp the clear tab and pull up and away from the phone to remove the battery.
Continue to pull slowly on the battery, until it is completely free from the phone.
crwdns2935229:028crwdne2935229:0
crwdns2947412:08crwdne2947412:0
Thanks! This is cool! I didn't know I can replace my OnePlus X's battery :)
Antonius Harijanto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
how to stick back panel to the device again?
Sarthak Ahir - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Double sided adhesive
Maxime LUCAS - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Does someone know a good vendor for a new Battery for the OPX that sells in europ? I also want to change the battery after 2 1/2 years.
Thanks in advance =)
Det Maat - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I just bought this :-) https://www.ebay.de/itm/382548678130
soren1967 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
