OnePlus 6T Rear Camera Replacement
  1. OnePlus 6T Rear Camera Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Rear Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    Remove the SIM card tray from the phone. Don't need to remove the actual card from the tray, just be careful you don't lose it…
    SayIDidIt™ - crwdns2934203:0crwdne2934203:0
  3. OnePlus 6T Rear Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Rear Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus 6T Rear Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus 6T Rear Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    Do you need to replace the glue when reassembling?
    S Marlin - crwdns2934203:0crwdne2934203:0
    It was sufficient for me to re-heat the adhesive from the phone.
    Also, I used a pair of tweezers to lift the initial corner, which was a breeze compared to the Jimmy’s as suggested by the guide.
    Michel Rummens - crwdns2934203:0crwdne2934203:0
    The gaps were very tight. After warming the adhesive, it was helpful to have a helper use a suction cup to tug on the back to enlarge the gap for the jimmy.
    tbrannam - crwdns2934203:0crwdne2934203:0
    Theres a big patch of glue on the right side of the camera. Be careful with this part, cuz ure proabably under the curved side trying to get inbetween and in my case this shattered the coating of the backside of my phone. It still works, but it has a spider skin on the back now.
    Shwyne - crwdns2934203:0crwdne2934203:0
  5. OnePlus 6T Rear Camera Replacement, Front Camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus 6T Rear Camera Replacement, Front Camera: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
  6. OnePlus 6T Rear Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
  7. OnePlus 6T Rear Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, gently remove the midframe and place it to the side.
  8. OnePlus 6T Rear Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
  9. OnePlus 6T Rear Camera Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus 6T Rear Camera Replacement, Motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
  10. OnePlus 6T Rear Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, disconnect the charging port flex connector, the main flex connector, and the screen flex connector at the bottom of the camera.
  11. OnePlus 6T Rear Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to disconnect the signal cables on the right side of the motherboard.
  12. OnePlus 6T Rear Camera Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus 6T Rear Camera Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the slider from the top of the phone with a spudger.
    • The slider is extremely delicate, so it is important you do not attempt to remove it from the sides.
    • Gently pull the motherboard from the left side and remove it from the phone.
  13. OnePlus 6T Rear Camera Replacement, Rear Camera: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus 6T Rear Camera Replacement, Rear Camera: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, disconnect the two metal rear camera tabs on the left side of the camera.
    • Remove the camera from its slot on the motherboard.
Rylee Cronin
crwdns2935283:010/15/19crwdne2935283:0
220 crwdns2915208:0crwdne2915208:0
Grand Valley State University, Team S4-G6, DeVasto Fall 2019 crwdns2935289:0Grand Valley State University, Team S4-G6, DeVasto Fall 2019crwdne2935289:0
GVSU-DEVASTO-F19S4G6
crwdns2935297:021crwdne2935297:0
In step 6 the screw under the humidity sensor is not shown. this needs to be removed as well
W W - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,345
