OnePlus 2 Battery Replacement
  1. OnePlus 2 Battery Replacement, SIM Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus 2 Battery Replacement, SIM Card: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus 2 Battery Replacement, SIM Card: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure that your phone is turned off before proceeding
    • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
  2. OnePlus 2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus 2 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus 2 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the SIM card tray on the back of the phone
    • Use your thumb to gently slide out the tray
  3. OnePlus 2 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SIM card tray
  4. OnePlus 2 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus 2 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus 2 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find and carefully remove all 6 rubber screw covers with the tweezers.
    • Unscrew all 18 screws from the mid frame.
    Be carefull the rubber screw covers bounce away and you won't find them.
    Max K - crwdns2934203:0crwdne2934203:0
  5. OnePlus 2 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus 2 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus 2 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
    • Slowly work your way around the phone releasing all the clips that hold the frame in place.
  6. OnePlus 2 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus 2 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus 2 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the spudger tool, pry the battery up from the adhesive.
    • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
    The battery connection was under a black tape in my phone. Remove the tape strip first.
    Jose Miranda - crwdns2934203:0crwdne2934203:0
    Removing the battery was really difficult. I had to apply a lot of force. You think something is going to break, but it eventually comes loose.
    Followed the procedure and all worked as expected. Thanks for this tutorial.
    Pedro Fonseca - crwdns2934203:0crwdne2934203:0
crwdns2935229:099crwdne2935229:0
Kayla Williams
crwdns2935283:010/01/15crwdne2935283:0
1.544 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-5, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 4-5, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S4G5
crwdns2935297:019crwdne2935297:0
crwdns2947412:021crwdne2947412:0
Nice to see that, thanx !
But do you know where it's possible to buy a new battery ?
I see "designed by oneplus" on it and I'm not sure it would be easy to find one on internet usual stores.
Fred Hamel - crwdns2934203:0crwdne2934203:0
You can look up a oneplus service center in your country/locality by going to your country's version of the oneplus site. There in the support -->Contact Us, you will find a list of places(service centers) you can go for repairs and a price list of all the parts and the service to replace them. Not sure if this works for every country, worked for me.
Zuke Denvar -
this is not a full help.. how do we suppose to buy official battery for onelus2?
and this method would be great if you upload a video in full detail without missing any point.
so, please do that. Thanks in advance!
shahfaishalkhan - crwdns2934203:0crwdne2934203:0
Use google.com and search for BLP597 that's the itemnumber of the battery in question. There are plenty of sellers available.
Markus Flaig -
any good battery for oneplus 2? i wanna buy a new battery for oneplus 2 can you please suggest me good battery for it? please tell me i really need it asap.
Thank you!!
Aalok Kumar - crwdns2934203:0crwdne2934203:0
Am baterie nouă, vrei?
mariananghel949 -
Thanks for your help, I bought my battery from ebay.com and it works fine and easy to replace. But I bought first battery when i received it i found it not looking new so I returned it then buy new one look new and working good.
big thanks :)
Ibrahim Afaneh - crwdns2934203:0crwdne2934203:0
Hey, could anyone please send me a link to where you bought the battery from.?
I’ve recently bought one on Ebay.de and it did not fit. Took for ages to deliver to Poland and then I had to pay for the return cost.
Michal Narbutt - crwdns2934203:0crwdne2934203:0
Hi.
You can get a replacement battery from “ www dot witrigs dot com/accessories-for-oneplus-two”. Can’t put the link in as the automated spam system blocks it. You can also find it on ebay if you’ll search for “Replace for OnePlus Two 2 A002 Blp597 3300mah Internal Battery”
Hope it helps
Tadas V - crwdns2934203:0crwdne2934203:0
Hi, after a couple of years my oneplus 2 started to had a really bad battery life so I ordered an original battery and replaced it with your manual. Thanks at first place for this detailed instructions. Sadly it starts to boot up and then immediately turns off. Then it restarts and there is the message shown that the device temperature is to high. Does anyone of you has an idea what this could cause? I was very careful while changing the battery. Thanks in advance
Christian Hoffmann - crwdns2934203:0crwdne2934203:0
My replacement battery was via Amazon but there are plenty on ebay too. Two commentd - the third “screw cover” red circle from the top is in the wrong place, it should be lower and left of the camera. Slightly more scarily, the battery connector is in the wrong place by a millimter or two, it was the same on the original battery - you need to gently peel the red covering from over the cable to the connector to give it a little extra flexibility.
Sean Kelly - crwdns2934203:0crwdne2934203:0
Thanks for the tip about the screw cover markings; I went ahead and adjusted them so they should be correct now. Looks like someone was in a bit of a hurry when they placed those :p
Jeff Suovanen -
How hard do you have to pry to free the battery?
I pried hard and the battery bent slightly but seemed to be almost integrated with the frame?
ub ingelsson - crwdns2934203:0crwdne2934203:0
Hi, i’am trying to find where to buy an original battery from france. Actually i ve bought the batery from Alliexpress, and in despite, the batery was described as original, the life cycle was too short. I’ ve tried to call the Technical service, and they can’t sell battery.
So anybody have an idea for me?
Best regard,
Michaël Hazan - crwdns2934203:0crwdne2934203:0
see on bol.com
Rudy Cornelis -
https://www.oneplus.in/experience-servic...
Choose appropriate service center and get it replaced for 1402/- INR. Safe and secure.
Nikita Zele - crwdns2934203:0crwdne2934203:0
This is for INDIA.
Nikita Zele -
For customers in India -
My One Plus 2 just turned 3 years. I went looking for a genuine battery and One Plus customer care wrote back saying that they’ve stopped the supply of parts for the One Plus 2. What an irresponsible company to stop selling batteries for a phone that they released in 2015. Don’t the morons realize that its only after 2-3 years that one needs a new battery?
I am not a guy who would buy a new phone just for the sake of buying one. Besides, its bad for the environment when you throw away a device that has more life in it. So, I keep looking harder and I got lucky when I tried an authorized service center in a smaller town. The proprietor was a gem of a man and he shipped me a new battery in one day! I paid Rs.1402, taxes included.
For friends in India looking to order a genuine One Plus 2 battery, visit the One Plus India service web pagee and search for the service center in “Vijayawada, Andhra Pradesh”.
https://www.oneplus.in/support/service-c...
Cheers!
Suresh R
Suresh R - crwdns2934203:0crwdne2934203:0
Just installed, the connector ribbon is longer than the original one so it bends to fit into place, not sure this is ideal..
marcopana - crwdns2934203:0crwdne2934203:0
Helped me, Thank you very much! :-)
Markus Stier - crwdns2934203:0crwdne2934203:0
On aliexpress are battery with larger capacity
€ 14,85 32%OFF | WISECOCO 4700mAh BLP597 Batterij Voor Oneplus 2 Een Plus 2 Twee A2001 Telefoon Nieuwste Productie Hoge Kwaliteit Batterij + tracking Code
https://s.click.aliexpress.com/e/mlQnd3q...
4700 mAh
Will this battery work in the oneplus 2?
pauluitbreda - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 53,397
