One Education Infinity:One Camera Assembly Replacement
crwdns2942287:0crwdne2942287:0In the One Education Infinity:One laptop, the front and rear facing cameras are one component. If you are experiencing performance issues with either camera this guide will help you replace them.
crwdns2944105:0crwdne2944105:0
Use a spudger to disconnect the black bundled cable connector from the motherboard.
Use a spudger to lift the black tab on top of the ZIF connector.
Slide the ribbon cable out of the connector.
Use a spudger to flip up the black retaining flap on the ZIF connector.
Pull the folded ribbon cable straight out of the connector.
Use a spudger to pry the battery away from the device.
Use a spudger to flip up the black flap on the camera's ZIF connector.
Pull the ribbon cable straight out of the connector.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the black cushion surrounding the camera lens.
Use tweezers to lift the camera assembly away from the device.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
