One Education Infinity Upper Hinge Assembly Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. One Education Infinity Upper Hinge Assembly Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Upper Hinge Assembly Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Upper Hinge Assembly Replacement, Upper Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement, Upper Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement, Upper Case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip open the laptop so that the screen is exposed.
    • We found it convenient to flip the laptop into tablet mode for added support.
    • Using a spudger, remove the six screw covers along the bezel of the screen.
  7. One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 2.8 mm Phillips #00 screws along the bezel.
  8. One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the two tabs on the top edge of the screen to pry the case apart.
    • Once the two top clips have been disengaged, start to work your way around the rest of the screen.
  9. One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all the clips have been popped off, remove the upper case from the back of the display assembly.
    • You may want to close the laptop while disconnecting the hinge-side edge, as it will give you extra clearance for the upper case.
  10. One Education Infinity Upper Hinge Assembly Replacement, Upper Hinge Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement, Upper Hinge Assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the twelve 3.8 mm Phillips #00 screws from the hinge brackets extending along the height of the display.
  11. One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the four pieces of black tape.
    • Peel back the antenna cable boards off of the display hinges.
    • Peel off the silver tape from the display hinges.
  12. One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 One Education Infinity Upper Hinge Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up both hinges, ensuring that they clear all tape and wires.
Austin Blakely
crwdns2935283:003/11/19crwdne2935283:0
21,623 crwdns2915208:0crwdne2915208:0
crwdns2935297:053crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,281crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 37
