This guide will allow you to remove the screen from the inside of the device in order to clean it or replace it. The screen on a device can easily crack. This repair is easy to do and does not require any special tools.
Remove the 4 rubber screw plugs using a spudger.
Remove the four 4.8mm mounting screws using a PH00 screwdriver.
Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
Gently lift the screen assembly away from the back cover assembly.
Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
Remove the ribbon cables.
Remove all 14 of the 3.6mm screws using a PH00 screwdriver.
Gently separate the screen from the plastic border/screen holder by pulling it off with your hands.
Remove the grey monitor from the glass screen cover by gently lifting it up.
بدي من هي الشاشة لمس فقط وين بلاقي
اين اجدها
بدي من هي الشاشة وين بلاقي
