OnHub Congestion-sensing Antenna Replacement
  1. OnHub Congestion-sensing Antenna Replacement, Speaker Grille: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnHub Congestion-sensing Antenna Replacement, Speaker Grille: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the device is unplugged before proceeding with the disassembly.
    • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
  2. OnHub Congestion-sensing Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the plastic opening tool under the speaker grille, and just above the light ring.
    • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
  3. OnHub Congestion-sensing Antenna Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnHub Congestion-sensing Antenna Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
    • There is a delicate wire connection to the antenna that is easily broken if not careful.
  4. OnHub Congestion-sensing Antenna Replacement, Congestion-sensing Antenna: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnHub Congestion-sensing Antenna Replacement, Congestion-sensing Antenna: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wire connection to the antenna by soldering it off.
    • For help with soldering and de-soldering check out the iFixit Soldering Guide
Joseph Ainsworth
crwdns2935283:002/10/16crwdne2935283:0
544 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-3, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 3-3, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S3G3
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 441
