This guide will show you how to remove and replace the lens box unit on the Olympus VR-350.
Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
Use the plastic opening tools and your fingers to pry the front plate from the camera.
Use your fingers to pry open the back cover.
Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
Pull the button pad up to fully reveal the visible ribbon cable.
Pull out the LCD screen and the ribbon cable.
Remove the metal plate that was underneath the LCD screen by removing the four 4 mm screws with the Phillips PH000 screwdriver.
Remove the orange ribbon cable from the connector on the left side of the motherboard.
To do this, gently lift up the small grey clasp and pull the cable ribbon.
There are two other small ribbon cables under the motherboard connected to the lens box. Pull them out from the motherboard.
Pull the lens box up and out to remove it.
crwdns2935229:05crwdne2935229:0
crwdns2917034:0crwdne2917034:0
Worked for a SH-21, with a couple of extra screws to remove. Thank you!
