Olympus VR-350 Lens Box Unit Replacement
  1. Olympus VR-350 Lens Box Unit Replacement, Front Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus VR-350 Lens Box Unit Replacement, Front Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Lens Box Unit Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Lens Box Unit Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus VR-350 Lens Box Unit Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus VR-350 Lens Box Unit Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 Lens Box Unit Replacement, Back Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus VR-350 Lens Box Unit Replacement, Back Plate: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
  5. Olympus VR-350 Lens Box Unit Replacement, LCD Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus VR-350 Lens Box Unit Replacement, LCD Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
  6. Olympus VR-350 Lens Box Unit Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the button pad up to fully reveal the visible ribbon cable.
    • You might need to bend the button pad out of the way.
  7. Olympus VR-350 Lens Box Unit Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the LCD screen and the ribbon cable.
    • The ribbon cable should be easy to pull out.
  8. Olympus VR-350 Lens Box Unit Replacement, Lens Box Unit: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal plate that was underneath the LCD screen by removing the four 4 mm screws with the Phillips PH000 screwdriver.
  9. Olympus VR-350 Lens Box Unit Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus VR-350 Lens Box Unit Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the orange ribbon cable from the connector on the left side of the motherboard.
    • To do this, gently lift up the small grey clasp and pull the cable ribbon.
  10. Olympus VR-350 Lens Box Unit Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are two other small ribbon cables under the motherboard connected to the lens box. Pull them out from the motherboard.
    • You may need to use force to pull out the ribbon cables.
  11. Olympus VR-350 Lens Box Unit Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the lens box up and out to remove it.
crwdns2935229:05crwdne2935229:0
Brooke
crwdns2935283:002/23/15crwdne2935283:0
278 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Leahy Winter 2015 crwdns2935289:0USF Tampa, Team 1-3, Leahy Winter 2015crwdne2935289:0
USFT-LEAHY-W15S1G3
Worked for a SH-21, with a couple of extra screws to remove. Thank you!
Rick Allies - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,964
