This guide will help you replace your LCD screen.
Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
Use the plastic opening tools and your fingers to pry the front plate from the camera.
Use your fingers to pry open the back cover.
Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
Pull the button pad up to fully reveal the visible ribbon cable.
Pull out the LCD screen and the ribbon cable.
