Olympus TG-820 iHS Lens Replacement
  1. Olympus TG-820 iHS Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS Lens Replacement, Back Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the camera so you are looking at the bottom.
    • Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
  5. Olympus TG-820 iHS Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the camera so you are looking at the side plate.
    • Remove the two 3.15mm Phillips #00 screws from the side plate of the camera.
  6. Olympus TG-820 iHS Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the camera so you are looking at the front plate.
    • Remove the two 3.8mm with the Phillips H1.5 from the front plate.
    • Remove the "Olympus" plate.
  7. Olympus TG-820 iHS Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove face plate.
  8. Olympus TG-820 iHS Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate three small black screws inside of the battery compartment.
    • Remove the 3.85mm Phillips #00 screw on the far left side.
    • Remove the two 5mm Phillips #00 screws on the right side
  9. Olympus TG-820 iHS Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the camera to be look at the top.
    • Remove the 5.4mm Phillips #00 screw on the top left side.
    • Remove the 7.4mm Phillips #00 screw next to the "ON/OFF" label.
    • Pry off top button plate with black nylon spudger.
  10. Olympus TG-820 iHS Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate to bottom of camera and locate bottom latch.
    • Wedge black nylon spudger in between bottom latch and camera base to release LCD Screen from camera.
    • Push firmly apart.
    • Some buttons might fall out.
  11. Olympus TG-820 iHS Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the camera to the LCD screen side that is now wedged open.
    • Locate the white ribbon cable and pull out from motherboard.
    • Locate the brown ribbon cable and pull out from motherboard.
  12. Olympus TG-820 iHS Lens Replacement, Lens: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus TG-820 iHS Lens Replacement, Lens: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four silver and one black screws using the Phillips #000 screwdriver from the metal holding plate and lift the plate out of the camera
    • Locate and remove the two screws on the left side of the camera using the Phillips #000, then remove the metal plates they rest on.
  13. Olympus TG-820 iHS Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tool, pry the black component out of the cameras casing.
    • The black component is connected to the motherboard using some ribbon cables, it is not necessary to disconnect these cables to replace the lens.
    • The black component will just fold out for access to the lens mechanism
  14. Olympus TG-820 iHS Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus TG-820 iHS Lens Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the three silver screws on the top of the lens, and remove them using the Phillips #000 screwdriver
    • Locate the two screws on the right side of the lens, and remove them with the Phillips #000 screwdriver.
    • After removing the screws, the lens will just lift free from the black component.
Leslie Cade
crwdns2935283:003/21/16crwdne2935283:0
343 crwdns2915208:0crwdne2915208:0
Clemson, Team 7-2, Benson Spring 2016 crwdns2935289:0Clemson, Team 7-2, Benson Spring 2016crwdne2935289:0
CLEM-BENSON-S16S7G2
crwdns2942667:0crwdne2942667:0 946
