Olympus Stylus Tough 6020 Motherboard Replacement
  1. Olympus Stylus Tough 6020 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Olympus Stylus Tough 6020 Motherboard Replacement, Bottom Plating: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, Bottom Plating: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, Bottom Plating: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Olympus Stylus Tough 6020 Motherboard Replacement, Top Plating: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, Top Plating: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, Top Plating: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Olympus Stylus Tough 6020 Motherboard Replacement, Left Plating: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, Left Plating: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Olympus Stylus Tough 6020 Motherboard Replacement, Black "Olympus" Face Plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, Black "Olympus" Face Plate: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, Black "Olympus" Face Plate: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Olympus Stylus Tough 6020 Motherboard Replacement, End Casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, End Casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, End Casing: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Olympus Stylus Tough 6020 Motherboard Replacement, Blue Face Plate: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, Blue Face Plate: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, Blue Face Plate: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Olympus Stylus Tough 6020 Motherboard Replacement, Back Plate: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Olympus Stylus Tough 6020 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
  10. Olympus Stylus Tough 6020 Motherboard Replacement, Ribbon Cables: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, disconnect the white ribbon cable from the motherboard.
    • Using tweezers, disconnect the brown ribbon cable from the motherboard.
  11. Olympus Stylus Tough 6020 Motherboard Replacement, Metal Panel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a screwdriver, unscrew the four screws off of the center metal panel.
    • Using tweezers, disconnect the ribbon cable from the motherboard.
    • Using tweezers, remove the metal panel.
  12. Olympus Stylus Tough 6020 Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a screwdriver, unscrew the black screw on the top left of the motherboard.
    • Using a screwdriver, unscrew the screw on the bottom left of the motherboard.
    • Using tweezers, disconnect the ribbon cable on the top right of the motherboard.
    • Using tweezers, disconnect the ribbon cable on the bottom right of the motherboard.
    • Using a spudger, pry the motherboard up.
  13. Olympus Stylus Tough 6020 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Stylus Tough 6020 Motherboard Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a soldering iron, desolder the red and white cables that are connected to the motherboard.
    • Using a soldering iron, desolder the blue wire on the back of the motherboard.
Jennica Jones
crwdns2935283:004/08/15crwdne2935283:0
203 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-6, Matresse Spring 2015 crwdns2935289:0Eastern Washington University, Team 2-6, Matresse Spring 2015crwdne2935289:0
EWU-MATRESSE-S15S2G6
I can no longer say "Youth is wasted on the young" Thanks
Edward Williams - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 812
