Olympus Stylus 760 LCD Screen Replacement
  1. Olympus Stylus 760 LCD Screen Replacement, Battery door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the door located on the bottom of the camera in an outward direction
  2. Olympus Stylus 760 LCD Screen Replacement, Release: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back on the red release tab located on the left side of the battery.
  3. Olympus Stylus 760 LCD Screen Replacement, Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide battery out of camera
  4. Olympus Stylus 760 LCD Screen Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 screws from the bottom of the camera
  5. Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
  6. Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 screws from the left side of the camera
  7. Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  8. Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the silver bracket off of the camera
  9. Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4 screws on the inner face of the camera.
    • Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  10. Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  11. Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 4 screws holding the LCD screen in place.
    • Be cautious of the brackets that come loose when you remove the 3 screws on the right side of the camera
    • LCD Screen is attached to 2 ribbon wires
  12. Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up on the small ribbon wire to disconnect it from the circuit board
    • Flip the little black clip up to remove the larger ribbon wire from the circuit board.
  13. Olympus Stylus 760 LCD Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic separating tool, remove the LCD screen from the plastic casing.
Ryan Cosgrove
crwdns2935283:002/10/12crwdne2935283:0
39 crwdns2915208:0crwdne2915208:0
James Madison, Team 3-3, Klein Spring 2012 crwdns2935289:0James Madison, Team 3-3, Klein Spring 2012crwdne2935289:0
JMU-KLEIN-S12S3G3
from where i can get repaired u760 camera
tahir zafar - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 1,887
