Remove the 2 screws from the bottom of the camera
Remove the screw from the right side of the camera.
Remove the two screws from the left side of the camera
Separate the front casing from the back using a plastic opening tool, gently.
Pull the silver bracket and buttons off of the camera
Remove the 2 screws on the right side of the camera.
Remove the 2 screws on the left side of the camera.
Pull the camera apart into 2 separate pieces.
Flip up clip on circuit ribbon, carefully
Detach the ribbon from the rear to the front and pull it out, gently.
