Olympus Pen E-PL7 LCD Screen Replacement
  1. Olympus Pen E-PL7 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Olympus Pen E-PL7 LCD Screen Replacement, LCD Screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
  3. Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fully extend the LCD assembly.
  4. Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
    • Use tweezers to remove the top LCD bracket.
  5. Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
    • Remove the LCD ribbon cable with a pair of tweezers.
    • The cover may fall off after the screws have been removed.
  6. Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the LCD screen up and away from the assembly.
    • Do not attempt to fully remove the screen, as it is attached to the assembly by a ribbon cable.
  7. Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to peel back the plastic cover.
    Be very careful i destroyed the wrong cables in that step.
    christoph hütt - crwdns2934203:0crwdne2934203:0
  8. Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to flip back the black bar on the LCD Ribbon ZIF connector.
  9. Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the ribbon cable out with tweezers.
  10. Olympus Pen E-PL7 LCD Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the LCD Screen.
    Thank you so much. Just fixed my cam!
    Ingo - crwdns2934203:0crwdne2934203:0
    There is more to it than shown here. You must remove the circuit board from the back of the old LCD screen, unplug those ribbon cables, transfer the circuit board to the new screen, and plug in the cables.
    Steve Reynolds - crwdns2934203:0crwdne2934203:0
Kelsea Weber
crwdns2935283:011/12/15crwdne2935283:0
20.688 crwdns2915208:0crwdne2915208:0
crwdns2935297:032crwdne2935297:0
crwdns2947412:010crwdne2947412:0
Where can I buy a replacement LCD screen?
Joshua Almeida - crwdns2934203:0crwdne2934203:0
You don't show the final part taking the glass away from outer and the board, as the screen replacements don't come with connector board
josollis - crwdns2934203:0crwdne2934203:0
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
Stephan Fagerer - crwdns2934203:0crwdne2934203:0
I have reassembled the unit after replacing the broken Ribbon, however my LCD images are inverted in normal mode not selfie mode. Do anyone know why ?
Thanks in advance
ah to lee - crwdns2934203:0crwdne2934203:0
Same problem, stuck in selfie mode. Upside down display in normal mode. Hope somebody could help. Thanks!
Rick Velasquez - crwdns2934203:0crwdne2934203:0
Je rencontre le même problème d'image inversé. Pas trouvé de solution ailleurs pour le moment...
Olivier Piebourg - crwdns2934203:0crwdne2934203:0
any one know where to get the hole flip mechanism for the screen?
mathias henriksson - crwdns2934203:0crwdne2934203:0
I have a question. The back frame of the flip screen is broken as well. Where can I get replacement? Thanks!
Kwokwai lau - crwdns2934203:0crwdne2934203:0
Hi, any luck finding that part?
SecondHex -
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 118
crwdns2942667:0crwdne2942667:0 11,392
