Olympus Pen E-PL7 Back Case Replacement
  1. Olympus Pen E-PL7 Back Case Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
  2. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4 mm reverse threaded Phillips screws from the bottom of the camera.
    • Reverse threaded screws tighten counter clockwise and loosen clockwise.
  3. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4 mm Phillips screws under the HDMI port cover.
  4. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the left hand grip.
  5. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the right hand grip.
  6. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip open the LCD.
    • Use a Phillips #00 screwdriver to remove the 2 mm screw beneath the LCD assembly.
  7. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
  8. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  9. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to remove the inner metal ring.
  10. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the two springs lying beneath the inner metal ring.
  11. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws.
  12. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4 mm Phillips screws.
  13. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press and hold the lens release button while using tweezers to remove the lens hook.
    • Use tweezers to remove the spring underneath the lens hook.
  14. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to remove the metal clip from the external flash mount.
  15. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the external flash port.
  16. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the second external flash clip with tweezers.
  17. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the external flash port casing to expose five more screws.
  18. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws.
    • Remove the 2 mm Phillips screw.
  19. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3.8 mm Phillips screws from the sides of the external flash connector.
  20. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the back case away from the camera.
    • Do not attempt to remove the back case, as it is attached to the camera by a ribbon cable.
  21. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the ribbon holding the back case to the camera, use the pointed end of a spudger to flip back the top bar on top of the ZIF connector.
  22. Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Pen E-PL7 Back Case Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to pull the ribbon out of the connector.
    • Remove the back case.
Kelsea Weber
crwdns2935283:011/12/15crwdne2935283:0
20 721 crwdns2915208:0crwdne2915208:0
crwdns2935297:032crwdne2935297:0
Loads of screws that don’t need to be removed just to remove the rear case.
Omit step 3,
Omit steps 6 to 13
Omit step 18
Take great care not to pull on ribbon cables
Rod Heeley - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 3,687
