Olympus FE-210 Lens Assembly Replacement
  1. Olympus FE-210 Lens Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Olympus FE-210 Lens Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Olympus FE-210 Lens Assembly Replacement, Front Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement, Front Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement, Front Casing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Olympus FE-210 Lens Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Olympus FE-210 Lens Assembly Replacement, Rear Casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  6. Olympus FE-210 Lens Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
  7. Olympus FE-210 Lens Assembly Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 pieces of translucent yellow tape.
    • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
  8. Olympus FE-210 Lens Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven 2.7 mm using a #00 screwdriver.
  9. Olympus FE-210 Lens Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
  10. Olympus FE-210 Lens Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the ribbon cord located on the left side of the motherboard.
    • Use tweezers or a spudger to lift the latch on the connector.
    • Carefully remove the cord from the connector.
  11. Olympus FE-210 Lens Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • De-solder the 2 connection points.
    • Be careful to not damage any part of the circuit board with the soldering iron.
  12. Olympus FE-210 Lens Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard from the camera casing.
  13. Olympus FE-210 Lens Assembly Replacement, Lens Assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3.6 mm screws using a #00 screwdriver.
  14. Olympus FE-210 Lens Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-210 Lens Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the lens to the left and pull up. The lens should easily come loose and slide right out.
Matt
crwdns2935283:001/25/11crwdne2935283:0
826 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-36, Regan Winter 2011 crwdns2935289:0Cal Poly, Team 4-36, Regan Winter 2011crwdne2935289:0
CPSU-REGAN-W11S4G36
This is also applicable to the Olympus FE170. I dismantled and repaired mine using this guide. Excellent!
Alan Shaw - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 6,698
