Olympus FE-170 Flash Assembly Replacement
  1. Olympus FE-170 Flash Assembly Replacement, Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement, Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
  2. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the battery compartment and remove the 2 screws in the top of the opening.
  3. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 exposed screws on the bottom of the camera.
  4. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
  5. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Uncover the video cable port on the side of the camera and remove the screw
  6. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
  7. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
  8. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
  9. Olympus FE-170 Flash Assembly Replacement, Flash Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement, Flash Assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement, Flash Assembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two small screws on the top of the flash itself.
  10. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to gently pry the top of the thin metal casing around the flash loose.
  11. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to gently pry the bottom of the thin metal casing around the flash loose.
  12. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to gently pull the metal casing off of the flash.
    • Remove the plastic flash diffuser by gently prying at the edges with your fingers.
  13. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw holding the flash circuit board in place.
  14. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the flash-bulb sub-assembly out of its place by using the pointed end of the spudger.
  15. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of the spudger to pull up both layers of tape on top of the flash-bulb sub-assembly.
    • Remove the wire layered in between the two sections of tape from the flash-bulb sub-assembly.
  16. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the flash circuit board and flash-bulb sub-assembly off from the front of the camera.
  17. Olympus FE-170 Flash Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus FE-170 Flash Assembly Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to push the black capacitor out from its slot.
    • Remove the entire flash assembly by gently pulling outward and away from the camera.
Tyler Hartwig
crwdns2935283:003/24/15crwdne2935283:0
337 crwdns2915208:0crwdne2915208:0
Baylor, Team 6-4, Shaver Spring 2015 crwdns2935289:0Baylor, Team 6-4, Shaver Spring 2015crwdne2935289:0
BU-SHAVER-S15S6G4
crwdns2942667:0crwdne2942667:0 458
