Olympus D590 Retainer Clip Replacement
    1. Olympus D590 Retainer Clip Replacement, Face Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove five baseplate screws using a Phillips #00 screwdriver.
    2. Olympus D590 Retainer Clip Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
    3. Olympus D590 Retainer Clip Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
    4. Olympus D590 Retainer Clip Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using tweezers, lift the rubber plate to expose the ports.
    5. Olympus D590 Retainer Clip Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove two screws from the ports using a Phillips #00 screwdriver.
    6. Olympus D590 Retainer Clip Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger to pry the faceplate away from the rest of the camera.
    7. Olympus D590 Retainer Clip Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
      • Damage to the connector line will prevent the on/off power switch's operational function.
    1. Olympus D590 Retainer Clip Replacement, Retainer Clip: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Orient the camera as shown, with the bottom facing up.
      • Open the retainer clip, by using your finger to push down and slide to the left.
      • The clip should pop open.
    2. Olympus D590 Retainer Clip Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hold the retainer clip down (without re-latching it).
      • Use a flathead screwdriver to start to pry out the pin holding the retainer clip's spring to the camera.
    3. Olympus D590 Retainer Clip Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use tweezers to continue to remove the pin.
    4. Olympus D590 Retainer Clip Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • When it feels loose, pull the pin all the way out with your fingers.
    5. Olympus D590 Retainer Clip Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
Katie
crwdns2935283:004/15/10crwdne2935283:0
31 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 28-23, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 28-23, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S28G23
crwdns2942667:0crwdne2942667:0 2,561
