Locate the battery latch on the bottom of the device.
Unscrew the one screw on the latch.
Remove the screw.
Remove the small black plastic piece positioned at the opening side of the battery latch.
You will now be able to lift and remove the thin metal covering from battery latch.
Locate the screw in the center crease of the opening of the battery latch.
