Ohmeda Engström Vent Engine Replacement
  1. Ohmeda Engström Vent Engine Replacement, Vent Engine: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the main chassis separated from the cart, position the device upright with the monitor centered to prevent any tipping.
    • Disconnect any external connectors as well as the display connector.
    • Make sure you are working in a clean and dust-free environment to avoid introducing any unwanted debris to the inside of the device.
  2. Ohmeda Engström Vent Engine Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ohmeda Engström Vent Engine Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down on the small grey tab below the exhalation valve.
    • While holding the tab down, you should be able to pull and extract the exhalation valve from the device.
  3. Ohmeda Engström Vent Engine Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are four Phillips screws to be removed at each corner of the back of the device.
    • Once the screws are removed, slide the housing along with display to reveal the main chassis.
  4. Ohmeda Engström Vent Engine Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ohmeda Engström Vent Engine Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the circuit board retainer in the upper right by unscrewing the four screws (M4-0.7 x 12mm Phillips) that hold it in place.
    • Disconnect the connectors coming from the vent engine to the circuitry.
    • Avoid any unnecessary contact with circuit board components.
  5. Ohmeda Engström Vent Engine Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The vent engine is held in place by two screws on each side of the device. Unscrew all four and remove the vent engine.
    • Install the new vent engine and screw into place.
    • Connect the vent engine connectors to the circuit board and reinstall the circuit board retainer.
Jonathan Honrada
crwdns2935283:004/10/20crwdne2935283:0
136 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G6, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G6, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G6
crwdns2942667:0crwdne2942667:0 293
