Ohmeda Engström Display Unit Screen Replacement
    1. Ohmeda Engström Display Unit Screen Replacement, Display Unit Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn off display unit, the power is located on the top left
    2. Ohmeda Engström Display Unit Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the Display Unit face down on an anti-static pad. Make sure that the release tabs are fully depressed.
      • Loosen four screws (L) on each side of the display unit.
      • Remove the rear enclosure and you will be able to see: the fan (26), the connector panel assembly (21), the encoder assembly (12), the battery (5), the speaker (20), and the gasket(28)
    3. Ohmeda Engström Display Unit Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Next, unplug all five wires from the display unit screen. These wires are labeled A, B, C, D, E.
      • Unscrew ten screws that are circled on the image.
    4. Ohmeda Engström Display Unit Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconect the backlight harness (G)
      • Slide Grommet (H) out of the mounting plate slot
      • Remove four screws that support the mounting plate
    5. Ohmeda Engström Display Unit Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the the LCD display away from the mounting plate. Pull some of the display ribbon cable (I) to the top side of the plate. Flip the LCD over to the left of the assembly
      • Disconnect the ribbon cable (J)
      • When replacing the LCD, pull the excess ribbon cable toward the bottom side of the plate as you lower the LCD on to the plate
ryan love
crwdns2935283:004/07/20crwdne2935283:0
156 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G6, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G6, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G6
crwdns2942667:0crwdne2942667:0 482
