Oculus Rift Development Kit 2 Headset Motherboard Replacement
crwdns2869540:0crwdne2869540:0: 3.2K
5
29
92
3,191
crwdns2955950:0crwdne2955950:0: 2
crwdns2960002:01crwdne2960002:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 7
crwdns2959974:07crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:030crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
If the device is not working properly this could be due to a broken headset motherboard. Common causes for motherboard failures include being exposed to static shock, overheating, or component failure.
    1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove front cover plate.
      • Unplug the USB and HDMI cables from the Oculus Rift DK2.
    2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
    3. Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • With the screws removed, gently pull the headband frame apart from the headset.
    1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
    1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Headset Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
    2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
      • Read the next step before removing the faceplate!
    3. Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
      • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
    4. Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
      • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
      • The headset should now be two separate pieces.
    5. Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
    6. Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
    7. Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oculus Rift Development Kit 2 Headset Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
Adam
crwdns2935283:001/20/15crwdne2935283:0
661 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-5, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 18-5, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S18G5
hi.
you know where possible buy the new motherboard?
Szatmari Attila - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 92
crwdns2959996:0crwdne2959996:0 3,191
