Oculus Rift Development Kit 2 Cable Hub Replacement
    1. Oculus Rift Development Kit 2 Cable Hub Replacement, Cable Hub: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the plastic opening tools, pry open the cable hub.
    2. Oculus Rift Development Kit 2 Cable Hub Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pry the cable away from the cable hub motherboard. It is attached with hot glue and should be removed easily.
      • Note that the cable is soldered on to the board. When prying the cable away from the hot glue, pull gently so as not to damage the soldered wire.
    3. Oculus Rift Development Kit 2 Cable Hub Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Desolder the wires as illustrated. This can be done by heating up the solder connecting the board and the wire. When the solder is liquified, pull the wire away from the board.
      • Need some help? Follow this guide to learn soldering basics.
crwdns2935229:05crwdne2935229:0
Alexandra Zaragoza
crwdns2935283:001/22/15crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-5, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 18-5, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S18G5
Buena guia, faltaria poder ver donde va soldado cada cable, he llevado mi cable a reparar y me lo han devuelto peor de lo que estaba, veo que han usado un cable de 4 hilos mas masa pero el original es de 5 hilos mas masa.
podria decirme donde van soldados los cables por la parte que va de la caja al usb ? ( el tramo corto )
Gracias
Hipolito Rodriguez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hipolito, pudíste arreglar el problema?
Yo tengo un DK2 que compré usado y vino sin la caja conectora del sensor. Hay forma de fabricar alguna? Reemeplazarla por alguna otra cosa?
Desde ya gracias.
Lea ndro - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Puedes conectar directamente el cable del sensor a las gafas, levantas la Tapita de goma que tiene y ahí lo conectas, con un alargador funciona correctamente también
My wires has a short in them where can i purchase a new one?
Ashley - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 97
crwdns2942667:0crwdne2942667:0 2,950
