If the LEDs in your ORFELD EV-600's brush roller attachment have gone out, this guide will show you how to replace them. The LEDs in the brush roller are a useful tool for seeing while vacuuming dark spaces. Please use caution when using a soldering iron.
Place the roller attachment bottom side up so you may access the brush.
Apply pressure with the iFixit opening tool to the tabbed side of the orange cap to release the roller brush.
Pull the roller brush from its socket one side at a time to remove it.
Remove the 11.5 mm screws surrounding the roller brush divot using a Phillips #0 screwdriver.
Remove the 11.5 mm screws located by the wheels using a Phillips #1 screwdriver.
Use the iFixit opening tool to pry the attachment open to pull the top free with your hands.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pull the LED strip out with your hands or tweezers as there is a small hole at the top of the strip.
Use a soldering iron to remove the wires.
Gently insert the new board. Make sure the LEDs line up with the little squares on the front of the roller brush. If it does not insert properly on the first try, keep adjusting.
