OPPO N1 Screen Replacement
    1. OPPO N1 Screen Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
    2. OPPO N1 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OPPO N1 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • In the photo we rotated the phone ninety degrees counterclockwise.
      • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
      • The rear case should then come free.
    1. OPPO N1 Screen Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OPPO N1 Screen Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
    2. OPPO N1 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the tweezers or your fingers to remove the sliver plates.
    3. OPPO N1 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the black plate with your fingers.
    4. OPPO N1 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OPPO N1 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OPPO N1 Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use tweezers or your fingers to pull up the connector tabs.
    5. OPPO N1 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OPPO N1 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
    1. OPPO N1 Screen Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use tweezers or fingers to remove the three connector tabs.
    2. OPPO N1 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OPPO N1 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use tweezers or your fingers to remove the motherboard.
    1. OPPO N1 Screen Replacement, Headphone Jack and Speaker Cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 4mm long screws using the ph0 Phillips head screw driver.
      • Remove the six 3mm long screws using the ph0 Phillips head screw driver.
    2. OPPO N1 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OPPO N1 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use tweezers or your fingers to remove the plastic cover.
    1. OPPO N1 Screen Replacement, Screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use tweezers to disconnect the connector tab.
    2. OPPO N1 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use tweezers to peel the black strip from the sticky tape attached to the phone so that the black strip will slide through the phone once the screen is removed.
      • Be gentle removing the black strip at this stage. It can easily tear and it must be removed in order to remove the screen.
    3. OPPO N1 Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OPPO N1 Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OPPO N1 Screen Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the blue opening tool into the crevice between the screen and the main body of the phone. Gently slide the tool around the edge of the phone.
    4. OPPO N1 Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OPPO N1 Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the blue opening tool in between the black screen and the white border and slide it around the edge of the black screen.
crwdns2935229:010crwdne2935229:0
Joshua Stone
crwdns2935283:009/26/14crwdne2935283:0
1,067 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 13-5, Staggers Fall 2014 crwdns2935289:0USF Tampa, Team 13-5, Staggers Fall 2014crwdne2935289:0
USFT-STAGGERS-F14S13G5
crwdns2936753:030crwdne2936753:0 111
crwdns2942667:0crwdne2942667:0 6,125
