OPPO N1 Motherboard Replacement
  1. OPPO N1 Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OPPO N1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OPPO N1 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
  4. OPPO N1 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tweezers or your fingers to remove the sliver plates.
  5. OPPO N1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black plate with your fingers.
  6. OPPO N1 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OPPO N1 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OPPO N1 Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers or your fingers to pull up the connector tabs.
  7. OPPO N1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OPPO N1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
  8. OPPO N1 Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers or fingers to remove the three connector tabs.
  9. OPPO N1 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OPPO N1 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to remove the motherboard.
crwdns2935229:08crwdne2935229:0
Joshua Stone
crwdns2935283:009/26/14crwdne2935283:0
1,067 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 13-5, Staggers Fall 2014 crwdns2935289:0USF Tampa, Team 13-5, Staggers Fall 2014crwdne2935289:0
USFT-STAGGERS-F14S13G5
how much is the mother board for oppo f1
gillianrain28 - crwdns2934203:0crwdne2934203:0
Hi,I used a wrong car charger on my oppo n1 in the wrong port and since then my phone went off and never turns on.
Can I I sent the unit to you for repair?
danjuma kolo - crwdns2934203:0crwdne2934203:0
I used a round pin car charger at the earpiece port of my oppo n1…and the phone went off…tiok it for repair but still not working…can u be off assistance
crwdns2942667:0crwdne2942667:0 5,479
