Nvidia Shield Tablet Speaker Replacement
crwdns2869540:0crwdne2869540:0: 3.3K
crwdns2942659:0crwdne2942659:0
crwdns2942661:0crwdne2942661:0
2
crwdns2942663:0crwdne2942663:0
28
crwdns2942665:0crwdne2942665:0
103
crwdns2942667:0crwdne2942667:0
3,329
crwdns2955950:0crwdne2955950:0: 2
crwdns2947422:01crwdne2947422:0, crwdns2947418:01crwdne2947418:0
crwdns2947416:0crwdne2947416:0
Completed: 1
crwdns2944093:01crwdne2944093:0
Favorites: 0
crwdns2942689:0crwdne2942689:0
crwdns2955944:0crwdne2955944:0: 30 - 40 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0 ↓
When your speakers are dust-free and clean, but still aren’t outputting the sound quality you once had or know to expect from your Nvidia Shield Tablet, it is likely that they need replacing. Before you begin, it is important to determine which speaker is malfunctioning! Listen carefully to the speaker on the top of your Shield Tablet, and to the speaker on the bottom of your Shield Tablet so you know which one, or possibly both, need replacing. This replacement will require some internal exploration of your device, so follow our steps carefully to replace your broken speaker.
    1. Nvidia Shield Tablet Speaker Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet Speaker Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • First, remove the stylus from your tablet.
    2. Nvidia Shield Tablet Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Anti-Static Wrist Strap
      $7.95
      • Set the tablet so the buttons, microSD, and stylus port are facing you.
      • Open the microSD slot.
      • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
      • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
    3. Nvidia Shield Tablet Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • As you remove your case, be aware of small clips along the edges.
      • Finally, set the old casing aside.
    1. Nvidia Shield Tablet Speaker Replacement, Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Orient your tablet so that the top of the tablet is furthest away from you.
      • Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
    2. Nvidia Shield Tablet Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 3.0 mm Phillips #00 screws securing the speaker.
    3. Nvidia Shield Tablet Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pry the speaker up with the flat end of a spudger.
      • Use a plastic opening tool to peel up the tape covering the speaker wire.
    4. Nvidia Shield Tablet Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      $7.95
      • Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
      • Finally, unplug the power source from your speaker using the precision tweezers.
      • Make sure you are using your anti-static wrist strap.
Molly Bauer
crwdns2935283:008/27/15crwdne2935283:0
1,478 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 2-2, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S2G2
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 3,329
