Nvidia Shield Tablet Motherboard Replacement
  1. Nvidia Shield Tablet Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First, remove the stylus from your tablet.
    Which website I can buy battery?
    Hang Chetha - crwdns2934203:0crwdne2934203:0
  2. Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $7.95
    • Carefully use the precision tweezers to unplug the ribbon cable.
    • Be sure to have your anti-static wrist strap on for this procedure.
    The rest of this guide is really good but this step is really ambiguous - "unplug the ribbon cable" doesn't make it clear which way to pull or which part should come away, and there's no picture to show it after it's been removed. I followed the guide to the letter, but after reassembly the tablet no longer registers the stylus in its sheath or on the screen and is therefore basically unusable. I've reopened it and replugged the cable but it doesn't stay in place properly - I've clearly broken something as a result of this ambiguous step, and my tablet is ruined :(
    Mark Hewitt - crwdns2934203:0crwdne2934203:0
  5. Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 6.5 mm Phillips #00 screws and seven 3.0 mm Phillips #00 screws.
  6. Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to disconnect the three black antenna cables from the motherboard.
    • Use the flat end of the spudger tool to carefully pry up the motherboard.
    • In the first Shield, the stylus ribbon cable is located under the right side of board. While there are 2 additional cables for the cameras underneath the left end of the board. Be sure to loosen the cameras before lifting the board.
  7. Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the positive and negative battery cables from the motherboard.
    • Make sure to note which wire goes where, you don't want to re-solder the wires backwards!
    • The motherboard should now come free.
Molly Bauer
crwdns2935283:008/27/15crwdne2935283:0
1 442 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 2-2, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S2G2
crwdns2935297:011crwdne2935297:0
crwdns2947412:09crwdne2947412:0
Where do you obtain a new motherboard?
imprintcave - crwdns2934203:0crwdne2934203:0
The real question is more about how to find a new shield tablet motherboard ??
willixlive - crwdns2934203:0crwdne2934203:0
where can i buy the motherboard
Gurjot Dhaliwal - crwdns2934203:0crwdne2934203:0
waar kan ik een nieuw shield moederbord kopen?
tom1vangestel - crwdns2934203:0crwdne2934203:0
Hello, I'm looking for a description of the various ribbon connectors on the motherboard.
I'm also looking for a hint to solve a problem I have after replacing the screen+digitizer: the right side (half) of the touch screen does'n work.
Laurent Zanoni - crwdns2934203:0crwdne2934203:0
Hi, i just did some work on mine. What connectors would you like to know about ?
Alexander Frederiks -
This is exactly the problem I have! Top left of the touch screen in my case.
Mark Hewitt -
I tried this today, please update the intructions.
The original Shield has a flatribbon on the right side for the stylus under the board.
And on the right side there a two flatribbons that connect the cameras, if you lift the board without loosening the cameras first you will ripp the cables.
Alexander Frederiks - crwdns2934203:0crwdne2934203:0
Following this steps you will rip off the Touchscreen Controller Ribbon - as it is actually as well on the pictures. The step #6 last photo showed damaged ribbon of the touch screen controller. Thanks for posting such non accurate and wrong information I damaged my tablet as actually the person who did the tutorial did too….. Really thanks …. This is a tutorial - How to damage your tablet
Krzysztof Gruca - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,603
