Nvidia Shield Tablet Motherboard Replacement
crwdns2869540:0crwdne2869540:0: 11K
5
28
111
10,712
crwdns2955950:0crwdne2955950:0: 11
crwdns2960004:02crwdne2960004:0, crwdns2960008:09crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 6
crwdns2959974:06crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 40 - 50 crwdns2931279:0crwdne2931279:0
Use this guide to replace the motherboard in your Nvidia Shield Tablet.
    1. Nvidia Shield Tablet Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • First, remove the stylus from your tablet.
    2. Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Anti-Static Wrist Strap
      $7.95
      • Set the tablet so the buttons, microSD, and stylus port are facing you.
      • Open the microSD slot.
      • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
      • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
    3. Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • As you remove your case, be aware of small clips along the edges.
      • Finally, set the old casing aside.
    1. Nvidia Shield Tablet Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      $7.95
      • Carefully use the precision tweezers to unplug the ribbon cable.
      • Be sure to have your anti-static wrist strap on for this procedure.
    2. Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two 6.5 mm Phillips #00 screws and seven 3.0 mm Phillips #00 screws.
    3. Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a pair of tweezers to disconnect the three black antenna cables from the motherboard.
      • Use the flat end of the spudger tool to carefully pry up the motherboard.
      • In the first Shield, the stylus ribbon cable is located under the right side of board. While there are 2 additional cables for the cameras underneath the left end of the board. Be sure to loosen the cameras before lifting the board.
    4. Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Desolder the positive and negative battery cables from the motherboard.
      • Make sure to note which wire goes where, you don't want to re-solder the wires backwards!
      • The motherboard should now come free.
Molly Bauer
crwdns2935283:008/27/15crwdne2935283:0
1,478 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 2-2, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S2G2
crwdns2947412:09crwdne2947412:0
Where do you obtain a new motherboard?
imprintcave - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The real question is more about how to find a new shield tablet motherboard ??
willixlive - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
waar kan ik een nieuw shield moederbord kopen?
tom1vangestel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello, I'm looking for a description of the various ribbon connectors on the motherboard.
I'm also looking for a hint to solve a problem I have after replacing the screen+digitizer: the right side (half) of the touch screen does'n work.
Laurent Zanoni - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 111
crwdns2959996:0crwdne2959996:0 10,712
