Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
Continue lifting up the panel all the way around the edges of the tablet.
Once all of the panel clips are unfastened, gently remove the back panel.
crwdns2935267:0crwdne2935267:0Tweezers$3.99
Use the angled tweezers to disconnect the black power cable from the mother board. The Cable should pop up from its slot when pulled.
Remove the screw adjacent to the WIFI Antenna using the J000 Philips head screw-driver.
Using the angled tweezers, begin removing the antenna from the device.
The black plastic piece of the antenna is attached to a copper colored film which can be pulled up using the tweezers.
The antenna should now be free from the device.
Odd question for you. I'm replacing the antena in a nvidia shield as an experimant, as was wonder if you know what type of connecter is used on the cable to the pcb. I dont want to desoder the exsisting antenna if i can help it as they are calabrated.
