Nvidia Shield Tablet K1 Micro USB Port Replacement
Ryan Butler
crwdns2944107:0crwdnd2944107:0Ryan Butlercrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 7, 2024crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937803:0crwdne2937803:0
crwdns2942287:0crwdne2942287:0
The Micro USB Port is for charging your tablet. If damage had ever occurred to it, you may find it loose, or not holding your charging cable.
crwdns2944105:0crwdne2944105:0
  1. Nvidia Shield Tablet K1 Micro USB Port Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
  2. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are clips holding the back panel to the rest of the case. You must apply some force to lift the back panel off.
    • Continue lifting up the panel all the way around the edges of the tablet.
    • Once all of the panel clips are unfastened, gently remove the back panel.
  3. Nvidia Shield Tablet K1 Micro USB Port Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery is heavily glued down so you will need to apply force while also exercising caution to not damage the rest of the device.
    • Using the blue plastic opening tool, place the lip of the tool underneath the battery as seen in the photo.
    You do not need to remove the battery.
    Dave Bogan - crwdns2934203:0crwdne2934203:0
  4. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once you have the blue plastic opening tool underneath the battery, work the tool around the edges of the battery similar to the technique used for the back panel.
  5. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the battery seems loose enough, use the blue plastic opening tool to lift the battery from the device.
    • The battery has four wires connecting it to the device. Be careful not to damage these wires while removing the battery.
    The white wire is for temperature line. What about the green wire? I have generic battery almost same size ang xapacity but it had only 3 wires, red black ang white. Green is missing
    Alberto MonicaMac103004 - crwdns2934203:0crwdne2934203:0
  6. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The wires to the battery are soldered to the motherboard. You may also check the soldering techniques guide for additional tips on soldering.
    • If your device's wiring doesn't exactly match these photos, snap a picture or make a note of what color wire goes to which contact on the motherboard before you detach them. (A mis-wired battery could cause electrical shorts and ruin the tablet for good.)
    • Using a soldering iron, desolder the four wires from the motherboard.
    • Once the wires are free from the motherboard, your battery should be free to remove from your device.
    Where can I buy a replacement battery??
    Robert Floyd - crwdns2934203:0crwdne2934203:0
    Where can I buy a replacement battery for my Nvidia tablet??
    Aliexpress -[L508 3,8 V 3,7 V 5000 mAh [3565152] PLIB; polímero de iones de litio/Li-ion batería para tablet pc de autonomía, carga de dispositivos, corrección keystone automática, e-book; BL-T17 celular
    Jose Antonio Fernandez - crwdns2934203:0crwdne2934203:0
    Those replacement batteries only have 2 or 3 wires. Any ideas since the one on the Shield has 4 wires?
    Raul San Martin - crwdns2934203:0crwdne2934203:0
  7. Nvidia Shield Tablet K1 Micro USB Port Replacement, WIFI Antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $3.99
    • Use the angled tweezers to disconnect the black power cable from the mother board. The Cable should pop up from its slot when pulled.
    • Make sure you disconnect the right cables. There are three of these.
    You do not need to disconnect the antenna power cable. You only need to disconnect the other 2 black power cables. Just pull the antenna out together with the Mboard.
    Did you not remove the battery and disoldered its cables? Why are they still in place?
    Nikos Tsarmpopoulos - crwdns2934203:0crwdne2934203:0
  8. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw adjacent to the WIFI Antenna using the J000 Philips head screw-driver.
    • Screw description: short black screw 20 mm length and 30 mm diameter.
  9. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the angled tweezers, begin removing the antenna from the device.
    You only need to free the antenna from the case. Leave it hanging from the Mboard.
  10. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The black plastic piece of the antenna is attached to a copper colored film which can be pulled up using the tweezers.
    • The antenna should now be free from the device.
    what replacement part can i use?
    just - crwdns2934203:0crwdne2934203:0
  11. Nvidia Shield Tablet K1 Micro USB Port Replacement, Speaker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement, Speaker: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement, Speaker: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful when removing the two pieces of tape because there are wires underneath the tape. Lifting too hard may accidentally rip out the wires.
    • While using the black plastic spudger tool, slowly lift the tape with your fingers and hold the wires down with the tool.
  12. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The audio input film is running underneath the foam piece and is fragile Be careful when removing this piece.
    • Slowly lift the black foam piece near the WIFI antenna to reveal the audio input film.
    • It is not necessary to remove the foam piece from the device entirely, just as long as you're able to free the audio input film without resistance.
  13. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the audio input films for each speaker from their respective ZIF (zero insertion force) connectors. These are the paper thin ribbons that have orange stripes along them.
    • Pull up the white latch on the ZIF connector, which will release the film and allow you to pull it out with tweezers.
    • Repeat this for both speakers.
    How did you remove the antenna in step 10 without removing the audio input films? In this photo, the antenna is still in place. Your instructions are a complete mess!!!
  14. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the power cables connecting the speakers to the battery. These are black wires with gold tips.
    • Again, use the tweezers to carefully pull them up from their places, they should pop right off.
    • There are three of these black wires in total, but only two belong to the speakers. follow the paths of the wires to make sure they are connected to a speaker.
    Have you not already removed these in Step 7 ???
    Removing cables already removed in step 7 ???
  15. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Free the speakers by removing their screws. You'll need the J000 Phillips-head screw Driver.
    • Each screw is roughly 30 mm in length and 30 mm in diameter.
    You only need to remove the speaker on the right of this photo, you can leave the other, longer one, in place.
    Battery in place, cables soldered, antenna in place, etc, as if you haven’t done any of the previous 14 steps. What a mess…
    I think what you meant was 3mm, not 30mm.
    Ken Kawakami - crwdns2934203:0crwdne2934203:0
  16. Nvidia Shield Tablet K1 Micro USB Port Replacement, Micro USB Port: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement, Micro USB Port: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers or your fingers lift the remaining black wires from the motherboard.
  17. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the remaining screws holding the motherboard in place.
    • Screws description: 5 short black screw 20mm length and 30mm diameter.
    • Screws description: 3 long black screw 40 mm length and 20 mm diameter.
    Mine had an additional screw on the top left corner of the motherboard. You can actually see it in this picture, directly above the left most screw.
    Eric Jones - crwdns2934203:0crwdne2934203:0
    I just realized that this is the screw described in step 8, which was supposed to be removed by this step. Guess I can't follow instructions.
    Eric Jones -
  18. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, grasp the brown ZIF (Zero Insertion Force) tab and pull outward to disconnect.
    • There is an orange chip that is connected to a white ZIF (Zero Insertion Force). Remove this by using either your fingers or the tweezers.
  19. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your tweezers, lightly lift around the edges to lift the motherboard.
    • When lifting the motherboard around the edge near the rear facing camera, there is a copper cable that is connected underneath the motherboard.
    • Before lifting the motherboard out, use your tweezers to disconnect rear camera's copper cable from the motherboard.
    Congratulations, you’ve just ripped the connector for the front camera when you lifted the motherboard out. The other speaker needs to be removed BEFORE lifting the motherboard, and the front camera, which is glued in, loosened so it lifts out with the motherboard.
    Frank Hovis - crwdns2934203:0crwdne2934203:0
    You can also lift the rear facing camera out. It’s held in only by some double sided tape. This will be necessary to plug it back in anyways.
    I wish I had read the users’ comments before attempting this repair….
  20. Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Tablet K1 Micro USB Port Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a soldering iron to desolder the Micro USB Port from the motherboard.
    • Now the Micro USB Port is free from the motherboard.
    You will need to plug in both cameras first and install them together with the Mboard as the connectors are on the underside.
    BIG NOTE: The entire bottom surface of the usb port is soldered down. You must first desolder the 5 contacts then heat the entire port until it comes loose.
    How are we supposed to desolder the entire port with a soldering iron alone, as listed in the Tools Section ???? Also, even if I remove the USB port, do I not need a replacement one? Where is it in the list of required parts? The worst iFixIt guide ever !!!
    There is no
    Because the port is soldered at all four corners and the base and the connectors; the only way to do this is a heat gun built specifically for desoldering. Please, Ryan Butler, do not mislead people so that they ruin their mainboards.
    To those reading this, buy a heat gun. If said heat gun costs more than a tablet from 2015, buy a new tablet and toss the old one. NVIDIA did not build this thing for home repair. This is disposable Android tech at its finest.
    This component is in a minefield of other transistors and plastic components, so you must be careful. The connections and copper love to de-tin or delaminate.
    Again, Ryan Butler's last step (step 20) is pure crap. Buy a heat gun.
    To resolder the port, the contacts must have copper under them and solder on them or you're boned.
    Nick - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Ryan Butler
crwdns2935283:002/09/16crwdne2935283:0
1.781 crwdns2915208:0crwdne2915208:0
crwdns2947412:012crwdne2947412:0
Where I can find a micro UBS port for Nvidia shield tablet ?
bryandu13eme - crwdns2934203:0crwdne2934203:0
Micro usb -B, Amazon.
Gigas Light -
it's a standard form factor, just check ebay
Daniel Monaghan - crwdns2934203:0crwdne2934203:0
my charging port is damaged,solder a new one or get a replacement board
Mr.lilnug - crwdns2934203:0crwdne2934203:0
It might be cheaper to solder a new one. I would compare prices, and decide if the price is worth soldering. If you want experience in soldering, go the solder route. Refining this skill will help later if you need to solder anything else.
Ryan Butler -
To remove the mainboard, it’s not necessary to remove the battery. I would strongly recommend to keep it in place.
De-soldering is sufficient.
Robert Klauco - crwdns2934203:0crwdne2934203:0
Thanks for the tip, I’m about to change the port in mine.
This guide doesn’t mention what type of adhesives will work for reassembly?
Dave Bogan -
How can I fix the USB port of my Nvidia Shield k1 any idea is better to replace a new port or solder .
Ivane_979@hotmail.com - crwdns2934203:0crwdne2934203:0
Manque: Tresse à dessouder, soudure laiton (fils batterie + fixation Micro USB) + pâte a braser, fer à souder CMS (air chaud) (pour pin Micro USB)
Manque: Micro usb port neuf
Inutile: (3,4,5) juste dessouder les 4 fils, ne pas essayer de la décoller, ou utiliser un dissolvant si autre besoin de réparation.
Erreur : 7, le câble noir n'est pas un câble d'alimentation, pas besoin de le déconnecter, voir étape 8 et 14
Dernière étape, il reste le plus difficile, ressouder un port USB neuf sur la carte mère, facile, souder les 5 pins beaucoup moins et surtout quasi impossible avec un fer à souder standard, peut être avec l'aide d'un microscope ?
Il faut un poste soudure CMS et de la pate à braser que l'on aura déposer sur les pins avant de fixer le port usb sur la carte mêre.
Tuto Utile pour les propriétaires de tablette ayant le matériel et le savoir faire en électronique, inutile pour les autres, entre le savoir faire et le prix de l'investissement matériel. Cherchez un professionnel et compter 60-80 euros.
Marc Leveille - crwdns2934203:0crwdne2934203:0
Thanks for the tips. I recommend using a de-soldering tool instead of braid though. It’s basically a spring loaded syringe that works backwards, sucking up the molten solder.
Dave Bogan -
I see that the micro usb's weldings are immediately accessible, it is possible think to weld a wireless receiver?
Antonino Perricone - crwdns2934203:0crwdne2934203:0
beware the very small ribbon cable from the bottom speaker under the tape near to the micro USB port - I was very careful when peeling back the tape but I did not realise the last corner covered that ever so this piece connected at 90 degrees horizontally and it so easiy tore through. Now I have to figure out how to fix that as it appears to be glued into the speaker :( I know this is years later but any suggestions for that are appreciated - and I will look through the site for the same
Rick Upchurch - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 24,104
