If the ports on the I/O board are broken or any other components have failed, the I/O board may need replacement. Follow the steps in this guide to replace the I/O board in your SHIELD TV.
Flip the device over and use a plastic opening tool to remove the bottom cover.
Remove the indicated cables and ribbon wires.
Remove the indicated four screws using the T6 Torx screwdriver.
Carefully tilt and pull out the I/O board from the device.
where do i get a new I/O Board ?
Yaaa, where can we get the I/O board? :-D
Yes, i need a replacement I/O board too, where can I find one?
Where can I get a replacement I/O board? What good are instructions without any availability for parts?
