You will need to replace the buttons in your controller if they stick easily or don't press down all the way. When removing the buttons, be careful as the buttons are not held in place by anything and can easily fall out.
Remove the indicated six screws using the T6 Torx screwdriver.
Use the plastic opening tool to pry the face of the controller from the body.
Carefully remove the indicated ribbon wires from the face of the controller.
Gently push the buttons towards you that you wish to replace.
A button
B button
Y button
X button
